T-100 Shimano Alivio 27-speed Bisiklet (v-brake) - 2015 model
Konunun Etiketleri
Şehir #Trabzon İlan Türü #Satılık
  • https://www.fahrradmanufaktur.de/en/katalog/trekking-2017/t-100-shimano-alivio-27-gang-v-brake - Bu bisikletin 2015 modeli elimdedir altta yazan özellikler 2015 modelin özellikleridir !!!
    Kadro - 52 cm 28" Jant
    300 Tl 'lik Abus 6500 Bordo Black kilit hediyemdir.
    Modell : T-100 Shimano Alivio 27-speed / V-Brake
    Size : Gents: 52, 57, 62 cm | Trapez 45, 50 cm | Anglais 55 cm
    Frame : 25 CrMo 4
    Headset : Tange Seiki Falcon FL-270C
    Fork : 25 CrMo 4
    Shifting System : Shimano Alivio RD-T4000
    Derailleur : Shimano Alivio FD-T4000
    Brakes : Shimano BR-T4000 V-Brake
    Headlights : B&M Lumotec LYT B Plus LED, 20 Lux with parking light
    Rear lights : B&M Toplight Flat Plus LED with parking light
    Carriers : Racktime Foldit Fix for SnapIt System with spring trap
    Saddle : Selle Royal Rio
    Seatpost : Humpert Ergotec Atar aluminium, patent
    Pedals : aluminium rubber claw VP-608
    Kickstand : Pletscher Zoom rear kickstand
    Chainguard : Horn Catena 05
    Mudguards : SKS Aluflex with edge guard
    Others : SKS Rookie
    Weight : 15, 6 kg
    Stem : Kalloy AL-812, aluminium, bracket adjustable, 25.4mm
    Handle bar : Humpert Ergotec MAS City/Trekking, 25.4mm
    Grips : Herrmans PrimErgo Jet with screw clamping
    Shift lever : Shimano Alivio SL-M4000
    Brake lever : Shimano BL-T4000 2-finger brake lever
    Tires : Schwalbe Citizen, 47-622, reflex
    Rims : Exal TX19, aluminium hollow chamber
    Spokes : Niro 2mm
    Front hub / Dynamo : Shimano DH-3N31 hub dynamo
    Rear hub : Shimano FH-RM70
    Sprocket : Shimano CS-HG20 11-32 teeth
    Chain : Shimano HG-53
    Inner bearing : Shimano BB-UN26 4-cant
    Bottom bracket : Shimano Acera FC-M391 48/36/26 teeth
    Gear ratio (front:rear) : 48/36/26 teeth : 11-32 teeth
    Colour : ebony matte
    T-100 Shimano Alivio 27-speed Bisiklet (v-brake) - 2015 modelT-100 Shimano Alivio 27-speed Bisiklet (v-brake) - 2015 modelT-100 Shimano Alivio 27-speed Bisiklet (v-brake) - 2015 model
    < Bu mesaj bu kişi tarafından değiştirildi LeDiableRoug3 -- 10 Haziran 2017; 21:39:40 >
