TR Tank'ı yarın sorarım hocam. Bi'de dikkatimi çeken bir nokta oldu; piyasada nispeten daha bilinen Spring Water - Milsu gibi markalar bile Fitting olarak Quick (DNT) kullanıyorlar. Bu tercihten dolayı sorun yaşıyor mu bu markalar acaba? < Bu ileti mobil sürüm kullanılarak atıldı > |
< Bu ileti mini sürüm kullanılarak atıldı > |
< Bu mesaj bu kişi tarafından değiştirildi atomcu -- 24 Kasım 2025; 23:52:10 > < Bu ileti mini sürüm kullanılarak atıldı > |
In this video, we share the 10 biggest lessons we’ve learned from testing 74 different water filters - including why some filters might actually make your water worse.
*Our website/comparison sheets (with full lab data):*
25 RO systems: https://bos-water.com/filters/reverse-osmosis-systems/best/#full-analysis
13 under sink ROs: https://bos-water.com/filters/reverse-osmosis-systems/under-sink-best/#full-analysis
12 countertop ROs: https://bos-water.com/filters/reverse-osmosis-systems/countertop-best/#full-analysis
19 under sink filters: https://bos-water.com/filters/under-sink/best/#full-analysis
26 countertop filters: https://bos-water.com/filters/countertop/best/#full-analysis
11 filter pitchers: https://bos-water.com/filters/pitchers/best/#full-analysis
7 gravity filters: https://bos-water.com/filters/gravity/best/#full-analysis
9 faucet filters: https://bos-water.com/filters/faucet/best/#full-analysis
5+ whole house filters: https://bos-water.com/filters/whole-house/best/#full-analysis
*Our comparison videos:*
https://www.youtube.com/watch?v=0ZqIGReL0Kk
https://www.youtube.com/watch?v=Yp_hCS-N4Xk
https://www.youtube.com/watch?v=-W65jKwcE2w
https://www.youtube.com/watch?v=4cYLD8Yhc7I
https://www.youtube.com/watch?v=QwJauKAFZBY
https://www.youtube.com/watch?v=IvDJLKEBI7U
https://www.youtube.com/watch?v=FMCNIB8xH8c
https://www.youtube.com/watch?v=qWrwAmjz49E
Table of Contents
00:00 – Intro
00:26 – #1 Potential Leaching
02:31 – #2 Aggressive Marketing
04:27 – #3 Filter Media
05:11 – #4 Filter Stages
05:51 – #5 Reverse Osmosis
06:27 – #6 Fake Reviews
07:20 – #7 TDS Confusion
08:48 – #8 NSF Standards & Filter Life
11:05 – #9 Made in USA
11:52 – #10 New Filters
12:37 – Outro
Our website: https://bos-water.com/
Some links are affiliate links. If you buy a product or service through such a link we earn a commission at no additional cost to you.
Amazon disclosure: As an Amazon Associate I earn from qualifying purchases.
Link to disclaimer policy: https://bos-water.com/terms-of-service/
#boswater #waterfilter #waterfilters #review #cleanwater #drinkingwater #watertest #waterfiltration #reverseosmosis #healthyliving #waterquality https://youtu.be/MZwj4y8GM-s?si=x6u0KdTEYePjbTsiyurt dışında da tr deki aynı teraneler dönüyor demek ki . İncelemeleri takip ettiğim güzel bir kanal. Türkçe alt yazılı olarak izlemenizi tavsiye ederim. Filtrelerden cihazlardan nsf hakkında dönen katakullilerden bahsediyor . |
daha alırken bu kadar ınanmama ınat alınca sorunlar olunca dusunemıyorum surecı |
cihazı değiştirme sebebiniz nedir? sadece tankı değiştirebilirsiniz aslında. |
Aslında 2 yıl yazdım ama bütün üniteyi alalı 4 sene oldu. Filtrelerini yılda bir değiştiriyordum sadece. Okuduğuma göre evden 3 ay, 6 ay gibi sürelerle uzaklaşır da kullanmazsanız Su filtrelerin içinde mantarlar oluşur tankınızda dahil dediği için ben komple değiştirmek istiyorum. < Bu ileti mobil sürüm kullanılarak atıldı > |
Aynen bu model, şu an kullandığım pompasız, ama su çok ince akıyor. Şebekemizde suyun tazyiki de düşük olduğu için pompalı modelden alacağım < Bu ileti mobil sürüm kullanılarak atıldı > |
membrandan sonra temiz suya bu kadar filtreden geçirmek ,suyu tekrar kirlenme riskini doğurabilir. bir tek et 100 taksanız membran sonuna yeter , o filtrelerin yaptığı her şeyi yapar. |
tds değerlerini biliyor musunuz ? kullandığınız membran ne kadar süre de bir değişim gerektiriyor ? membranın markası modeli vs ? eğer senelik değişim yapıyorsanz flt 75 modelini 420 lk atık kısıcı ile fiyatı zamlanmadan alın geçin. pompalı versiyonu ile ama . antalyada kireç çok diye geri dönüşler alıyoruz burada. pompasız cihaz iyi olmaz. 3 kişi için yeterli olur . Sediment filtreyi 6 ayda bir değişim iyi olabilir . bölgenizdeki çamur durumuna göre . < Bu mesaj bu kişi tarafından değiştirildi ZevkiSefa -- 26 Kasım 2025; 12:26:16 > |
