Acer s232hl led monitör 144 hz monitör ile takas olur
    1 Acer s232hl led monitör 144 hz monitör ile takas olur
    144 hz monitör ile takas olabilir.
    Özellikler Acer s232hl  led monitör 144 hz monitör ile takas olur
    Display Type LED-backlit LCD monitor / TFT active matrix
    Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
    Contrast Ratio 12000000:1 (dynamic)
    Color Support 16.7 million colors
    Dimensions (WxDxH) 21.4 in x 6.5 in x 15.4 in
    Horizontal Viewing Angle 176
    Vertical Viewing Angle 170
    Brightness 250 cd/m²
    Backlight Technology WLED
    Vertical Refresh Rate 75 Hz
    ManufacturerAcer
    POWER DEVICE
    Nominal Voltage AC 120/230 V
    Power Consumption Operational 26 Watt
    CONNECTIVITY
    Interfaces DVI-D
    HDMI
    VGA
    MISCELLANEOUS
    Microsoft Certifications Compatible with Windows 7
    Color glossy black
    DISPLAY
    Image Brightness 250 cd/m2
    Video Format 1080p (Full HD)
    POWER
    Power Consumption Stand by / Sleep 0.69 Watt
    VIDEO
    Video Output none
    ENVIRONMENTAL STANDARDS
    ENERGY STAR Certified Yes
    VIDEO INPUT
    Digital Video Standard Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
    MECHANICAL
    Display Position Adjustments Tilt
    Tilt Angle 20
    DIMENSIONS & WEIGHT
    Width 21.4 in
    Depth 6.5 in
    Height 15.4 in
    Weight 6.61 lbs
    HEADER
    Brand Acer
    Product Line Acer
    Model S232HL Abid
    Packaged Quantity 1
    Compatibility PC
    PROJECTOR
    Max V-Sync Rate 75 Hz
    SERVICE & SUPPORT
    Type 3 years warranty
    SERVICE & SUPPORT DETAILS
    Type limited warranty
    Location carry-in
    Full Contract Period 3 years
    TV TUNER
    TV Tuner Presence No
    INTERFACES
    Type DVI-D, HDMI, VGA
    GENERAL
    ManufacturerAcer
    Fiyat : 500 TL Miktar : 1 Sıfır Ürün : Hayır Garantisi Var : Hayır Satıldığı Şehir : İstanbul,Maltepe Kargo Ücreti : Alıcı Öder Kargo Şirketi : Diğer İlan Durum : Satışa Açık
