Solar Şarj Kontrol Max PV array power
  • Konu İstatistikleri
  • Son Yorum 7 ay
  • Cevaplayan Üyeler 1
  • Konu Sahibinin Yazdıkları 1
  • Son 1 Saatteki Mesajlar 1
  • Konuya En Çok Yazanlar
  • mugennotsukiyomi (1 mesaj)
  • Konuya Yazanların Platform Dağılımı
  • Masaüstü (1 mesaj)
  • Elimde 40A lik şarj kontrol cihazı var. Sabah ve akşam verimi arttırmak istiyorum.
    Ekteki bilgilere göre 12v luk sistem için 780W'a kadar arttırabilir miyim?
    "if the power of PV array exceeds the rated
    charging power of controller, then the charging time as per the rated power will be
    prolonged, so that more energy can be obtained for charging the battery. However, in
    the practical application, the maximum power of PV array shall be not greater than 1.5
    x the rated charging power of controller. If the maximum power of PV array exceeds
    the rated charging power of controller too much, it will not only cause the waste of PV
    modules, but also increase the open-circuit voltage of PV array due to the influence of
    environmental temperature, which may make the probability of damage to the
    controller rise. Therefore, it is very important to configure the system reasonably. For
    the recommended maximum power of PV array for this controller, please refer to the
    table below:"
