İNCELEME: Audio System Digital Music Changer - ORJİNAL TEYBE USB SD AUX (7. sayfa)
3 Misafir - 3 Masaüstü
11 oy
  • Supported memory cards and USB sticks:
    1.Max 8GB (2GB is most recommended);SD card is more recommended than USB stick.
    2.Please format USB stick or SD card with FAT16 or FAT32 format before you save files and folders in USB/SD.
    3. Imposed folder naming system: CD01, CD02, CD03 ....
    Doesn't read sub-folder and gets confused with other names in root of the drive.
    4.Supports up to 15 folders (depending on the radio type) on your USB/SD.
    5.Any number of songs can be stored in each folder, but the display of most radio models can only screen 99 track titles; Saving too big file(over 50MB) in any folder may also cause intermittent performance
    6.Using music files formats other than WMA and MP3 may also cause intermittent performance.
    7. The playback order of songs is in line with their created date.
    8.Sometimes,to remove defect on software of car audio system, you may need to disconnect the battery or remove the fuse to reset the car audio system.
    9.To use the Aux-In port, it's necessary to remove the USB or SD card.
    10.YT-M06 may does not work with some of new Kingston brand USB stick.
    Yatour YT-M06 ile Audio System RE-06 birebir ayni, o yuzden bu aciklamalar Audio System icin de gecerli.
    FAT32 8GB'a kadar SD kart desteklemesi lazim. Mp3 ve WMA'dan baska dosya bulunmadigindan ve alt klasor bulunmadigindan eminseniz bence baska bir SD kart deneyin.
    Zira Kingston'larda sorun olabilecegi yazilmis.
    Ben 2 farkli 8 GB Sandisk SD, 8 GB Toshiba USB, 4 GB cin isi USB denedim, hepsi calisti
  • fat32 formatinda 16GB Kingston marka flash bellek ile sorunsuz kullaniyorum. Bir klasore 250 sarki koydum hepsini goruyor, TRK 99'dan sonra TRK 01 olarak 100. sarkidan devam ediyor. Bilginize arkadaslar...
  • Arkadaşlar 2006 Almera'ya bu cihazdan aldım. Nissan grubunda elektriği dışardan almak gerekiyor. ekstradan 2 kablo var. (ACC ve 12V.). Fakat problem şu ki anahtarı her çıkarmada alet birinci şarkıdan başlıyor. Montajda bir problem yok. ACC kontağa 12V direk aküden gelen kabloya eklendi.
    Bir önerisi olan ya da Almeraya bu cihazı sorunsuz bağlayan varsa nasıl yaptığını söylerse sevinirim. Teşekkürler şimdiden
    Orijinalden alıntı: dersuuzala
    2006 model almera aracıma bağlantı yapıldı böyle bir durumla karşılaşmadım.Bağlantı yapılırken kablonun biri kontak açıkken elektriğe bakılıp bağlandı diğeride kontak kapalıyken elektriğe bakılıp bağlandı.Muhtemelen yine bağlantı sorunudur sizin durumunuz.
  • Bitirgic Kardeş,
    Sarı olan(BAT) sarı kabloya, kırmızı olan(acc) pembe kabloya bağlandı. kontak açıkken test edildi (ikisinde de elektirk var) Kontak kapalı iken test edildi.(ACC de yok, BAT da var)
    Sonuç: kontağı çıkardıktan sonra arkadaki led sönüyor. Cihaz sıfırdan başlıyor.
    Sandisk 4gb, sandisk 2gb, sd card (birkaç çeşit), kingston 1gb denendi. Hepsinde sonuç aynı. Senin usb markası ne kardeş?
    En son 2 ucu birleştirip sarıya bağladım. Evet, bu sefer o hatayı yapmadı. Ama cihaz sürekli elektirk aldığı için ısınma problemi çıktı. Belki başka problemlerde çıkar.
    Önerini bekliyorum. Teşekkürler.
    Bitirgic Kardeş,
    Ben toshiba ve kingston kullanıyorum bağlantı aynen benimkinde de dediğin gibi yapıldı.Kontağı çıkarınca led sönüyor.Isınma problemi bende de var ama her kullananın cihazı bir miktar ısınıyor öyle çok ısınmıyor ama.Sürekli elektrik alırsan bir yerleri mutlaka yakarsın çok ısınmadan.Aşağıdaki resimdek işaretlediğim bölgedeki kablolara bağlantı yapıldıç
    < Bu mesaj bu kişi tarafından değiştirildi bitirgic -- 4 Temmuz 2012; 17:06:48 >
    Orijinalden alıntı: bitirgic
    Bitirgic Kardeş,
    Kardeş yukardım gösterdiğin bölmede ki kablolardan sarı ve pembe olana bağlatı yapıldı. Cihazla okuma yapıldı sonra bağlandı. Bağlantıda bir problem yok yani. Ama sonuç hep aynı. kontağı çıkarıyorum. C05 Parça 55, C08 PARÇA 99 falan yzıyor. Sonra C01 PARÇA01den çalmaya başlıyor. Her yöntemi denedim.
    Dediğin usb bellekleri denemedim. Belki ondandır.
    Birde random tuşu çalışıyor mu? (3 tuşu)
    Teşekkürler
    Kardeş yukardım gösterdiğin bölmede ki kablolardan sarı ve pembe olana bağlatı yapıldı. Cihazla okuma yapıldı sonra bağlandı. Bağlantıda bir problem yok yani. Ama sonuç hep aynı. kontağı çıkarıyorum. C05 Parça 55, C08 PARÇA 99 falan yazıyor. Sonra C01 PARÇA01den çalmaya başlıyor. Her yöntemi denedim.
    Teşekkürler
    bende o cd sayma C08 99 yazması ilk açıldığında oluyor ve ilk kaldığı parçadan başlıyor ve çok kısa sürüyor.Random tuşu çalışmıyor.Ben İstanbul'dayım sizde İstanbul'da iseniz taktırdığım yerin adresini vereyim bir de oraya baktırın.Yardımcı olamadım kusura bakmayın.
    Teşekkürler
    Kardeş yardım etmeyi düşünmen yeterli teşekkür ederim.
  • Merhabalar. 2000 Model Focus 'um var. 5000RDS Teype uyumlu galiba :)
    Radyodan daha iyi bir ses çıkışı elde ederim değil mi ? Bugün yarın sipariş vereceğim.İlginize Teşekkür ederim güzel bir İnceleme olmuş DonanımHaber Bunlar için var :)
    Orijinalden alıntı: Skrbsr96
    FORD FOCUS MK1 -1998-2004-Arası mevcut diyor. Yine de aracınıza uyuyor mu, stok var mı diye sorarsınız.
    Teybinize CD kalitesinde USB, SD, AUX player taktırmış oluyorsunuz, dolayısıyla radyo dinlemekten daha keyifli olacaktır.
  • eşsiz bi rehber olmuş emeğinize sağlık
    alıp kendim uğraşamam ancak bi dükkan da komple bu işlemlerin hepsi yapılsa iyi olurdu
  • (Audio System RENAULT 8 PİN CİHAZ) 2001 Clio Symbol orjinal kasetli radyo teype (cd çalar yok) taktım. Teyp soketinde yeri var, cihazı görüyor fakat problemli. Otomatik tarıyor klasörleri buluyor çoğu zaman şarkı başlamıyor. Çok nadir şarkı başlıyor, ancak parça değiştirmek için ileriye basınca şarkı kesliliyor, sessizleşiyor. Müzik kalitesi tatmin edici değil. Daha önce 5,6 tane Audio system takan, 13,14 tane başka marka takan oto teypçi arkadadaşım akıl erdiremedi. Ya cihaz problemli, yada araca uyum sağlamadı. Clioya taktıracak arkadaşlar alırken iyi düşünsünler çevresinde kullanıp randıman alan varsa taktırsınlar. ben iade ediyorum
    Orijinalden alıntı: Vejez
    Teşekkürler.
    Zaten sadece teybi söküp soketleri takmaktan ibaret. Onu da istediğiniz yere yaptırabilirsiniz.
    Orijinalden alıntı: erxmen
    Bilgilendirme için teşekkürler, geçmiş olsun.
  • aleti peugeot 3008 aracıma kendim kurdum çalıştırdım. ileri, geri, random, intro çalışıyor fakat ekranda hiçir şey yok dolayısıyla list tuşu da çalışmadığından istediğin şarkıyı bulman çok zor.
    diyelim 4. CD nin 45. parçasını seçeceksin. 4. CD yi seçip 45 kere ileri tıklaman lazım.
    sizde durum nasıl? istediğiniz şarkıya nasıl hızlı erişim yapıyorsunuz.?
  • Merhabalar benim aracım 2006 model peugeot 307 comfor modelidir. aracımda mp3 cd leri okumuyor orjinal track cd leri okuyor bu 1 cd ye 16-17 müzik sığıyor.Bunun için aparatı taktırmak istiyorum. Bu bahsettiğiniz aparatın aracıma göre olanı varmıdır acaba ?
  • Vallahi 2005 fiesta uyumlusunu bulamadik hicbiyerde,
    Alternatif cozum onerisi olan var midir durum ile ilgili?
  • selam
    2004 peugeot 206 ya takmak için servisten bir şeylerin aktif ettirmesi gerekli mi? ek maliyet çıkarmı?
  • Merhaba,
    İncelemeniz ve bilgilendirmeniz için çok teşekkürler..
    Ekstra bir şey sorabilir miyim? Sadece Klasörleri mi numaralandırmak gerekiyor yoksa parçaların da mı numaralandırılması gerekiyor?
    Teşekkürler..
